can TASK be used in synthesisable Verilog RTL code?
johnli100
Member level 1
rtl verilog task
can task be used in the synthesisable RTL code? If can, would someone please give me an example.
thanks!
verilog task rtl
No.
Never use that, although it is supported in IEEE P1364.1 / D1.6 .
Use function insteadly.
Yes, if your compiler supports it.
Here's an example copied from the Xilinx XST User Gude (a synthesis tool for FPGA).
module EXAMPLE (A, B, CIN, S, COUT);
  input [3:0] A, B;
  input CIN;
  output [3:0] S;
  output COUT;
  reg [3:0] S;
  reg COUT;
  reg [1:0] S0, S1, S2, S3;
  task ADD;
    input A, B, CIN;
    output [1:0] C;
    reg [1:0] C;
    reg S, COUT;
    begin
      S = A ^ B ^ CIN;
      COUT = (A&B) | (A&CIN) | (B&CIN);
      C = {COUT, S};
    end
  endtask
  always @(A or B or CIN)
    begin
    ADD (A[0], B[0], CIN, S0);
    ADD (A[1], B[1], S0[1], S1);
    ADD (A[2], B[2], S1[1], S2);
    ADD (A[3], B[3], S2[1], S3);
    S = {S3[0], S2[0], S1[0], S0[0]};
    COUT = S3[1];
  end
endmodule
Or do you need to see an example with a clock? I don't have one.
