narayani
I have designed low noise amplifier and simulated stability factor values and am getting the some stability factor values as negatives values for some frequencies.
If it comes negative values for some frequencies is it o.k. does it mean unstable or negative value of stability should not come at all.
Can it stability factor values comes negative value, is it not acceptable or it should not come negative value of stability factor at all.
