Can someone help me identify this power regulator so i can get a replacement?
dasitmane
Newbie level 2
Newbie level 2
I have one of the below regulators that i used with a variable power supply with a 5.5mm plug and i need to get another one, unfortunately i do not have the skills to build one myself and i am having trouble sourcing one.
Can anyone tell me what i should be looking for as a replacement?
Thanks
That sure is NOT a regulator. It's a resistor, a MOV and an LED. Is there any kind of information on that quality-looking assembly? Part number, manufacturer's name or something? Probably not; the manufacturer was apparently too ashamed.
I got it with an electroplating kit years ago, the led flashes when the voltage is too high and it works as a cut out circuit. Any idea where i can get another one like it?
There are only 3 parts. You should be able to test them for shorts or opens. Without a schematic it's impossible to tell you WHAT to 'get'.
