scream_er
Member level 5
1) The mathematical analysis shows that QPSK can be used either to double the data rate compared with a BPSK system while maintaining the same bandwidth of the signal.
I believe in this statement QPSK can have double the data rate since each symbol is coded by two bits in QPSK compared to one bit per symbol in BPSK. I would like to know how they both can have the same bandwidth when I am sending more bits in QPSK compared to BPSK.
2)To maintain the data-rate of BPSK but halving the bandwidth needed for QPSK. In this latter case, the BER of QPSK is exactly the same as the BER of BPSK.
In this statement I believe both QPSK and BPSK have same BER because the data rate is same. And again, how can you same data rate by halving the bandwidth of QPSK.
Thanks
Thanks
