jayanth.devarayanadurga
Banned
- Joined
- Dec 4, 2012
- Messages
- 4,294
- Helped
- 822
- Reputation
- 1,654
- Reaction score
- 793
- Trophy points
- 1,393
- Location
- Bangalore, India
- Activity points
- 0
Here is my code and I have attached my Project files.
MCU PIC18F4580
Fosc 16 MHz
myflt contains the adc value and it is compared with values in V[]? If any value matches then ctr is incremented and if ctr > 0 i.e, if any value matches then LED turns ON. Upto here it is working fine but when I change the adc value then LED doesn't turn OFF even if myflt doesn't match with any value of V[].
MCU PIC18F4580
Fosc 16 MHz
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 #include <p18f4580.h> #include <delays.h> #include <math.h> #pragma config WDT = OFF #pragma config OSC = HS #pragma config PWRT = ON #pragma config LVP = OFF #define ldata PORTD #define rs PORTBbits.RB0 //define reset bit #define rw PORTBbits.RB1 //define read/write bit #define en PORTBbits.RB2 //define enable bit //TCY = 0.25 us //Function prototypes void float2string(float fp_num); void adc_read(); void Delay10TCYx(unsigned char unit); void Delay100TCYx(unsigned char unit); void Delay1KTCYx(unsigned char unit); void Delay10KTCYx(unsigned char unit); void lcdinit(); void lcdcmd (char value); void lcddata(char value); void lcdstring(unsigned char *lcd_data); void MSDelay(int itime); float V[9] = {3.31, 3.32, 3.33, 3.34, 3.35, 3.36, 3.37, 3.38, 3.39}; float I[8] = {0,5,6,16.69,3.94,3,3, 32.44}; float R[9] = {0, 1.1, 1.21, 1.37 ,1.32, 1.50, 1.35, 1.6, 1}; unsigned char disp[] = "ADC Value = ", ctr = 0; unsigned int adc_val = 0; unsigned char myString[8]; unsigned int iladc_val = 0, i = 0; float dladc_val = 0.0, old_val, myflt; //Function Definition //Sub Function void float2string(float fp_num){ long int befdec, aftdec; fp_num = ceil(fp_num * 100) / 100; myflt = fp_num; befdec = fp_num; // Fractional part is truncated // 12.163456 becomes 12 aftdec = fp_num * 100; // 12.163456 becomes 1216 aftdec = aftdec - (befdec * 100); // 1216 - 1200 = 16 if (fp_num < 1) { myString[0] = '0'; myString[1] = '.'; myString[2] = (aftdec/10) + 48; myString[3] = (aftdec/1)%10 + 48; myString[4] = '\0'; myString[5] = ' '; myString[6] = ' '; myString[7] = '\0'; } else if ((fp_num >= 1) && (fp_num < 10)) { myString[0] = (befdec/1)%10 + 48; myString[1] = '.'; myString[2] = (aftdec/10) + 48; myString[3] = (aftdec/1)%10 + 48; myString[4] = '\0'; myString[5] = '\0'; myString[6] = '\0'; myString[7] = '\0'; } else if ((fp_num >= 10) && (fp_num < 100)) { myString[0] = (befdec/10) + 48; myString[1] = (befdec/1)%10 + 48; myString[2] = '.'; myString[3] = (aftdec/10) + 48; myString[4] = (aftdec/1)%10 + 48; myString[5] = '\0'; myString[6] = ' '; myString[7] = '\0'; } else if ((fp_num >= 100) && (fp_num < 1000)) { myString[0] = (befdec/100) + 48; myString[1] = (befdec/10)%10 + 48; myString[2] = (befdec/1)%10 + 48; myString[3] = '.'; myString[4] = (aftdec/10) + 48; myString[5] = '\0'; myString[6] = ' '; myString[7] = '\0'; } else if ((fp_num >= 1000) && (fp_num < 10000)) { myString[0] = (befdec/1000) + 48; myString[1] = (befdec/100)%10 + 48; myString[2] = (befdec/10)%10 + 48; myString[3] = (befdec/1)%10 + 48; myString[4] = '.'; myString[5] = (aftdec/10) + 48; myString[6] = ' '; myString[7] = '\0'; } else if ((fp_num >= 10000) && (fp_num < 100000)) { myString[0] = (befdec/10000) + 48; myString[1] = (befdec/1000)%10 + 48; myString[2] = (befdec/100)%10 + 48; myString[3] = (befdec/10)%10 + 48; myString[4] = (befdec/1)%10 + 48; myString[5] = '.'; myString[6] = (aftdec/10) + 48; myString[7] = '\0'; } } void adc_read() { ADRESL = 0x00; ADRESH = 0x00; ADCON0bits.ADON = 1; Delay100TCYx(200); ADCON0bits.GO = 1; while(ADCON0bits.GO); ADCON0bits.ADON = 0; iladc_val = ADRESH; // copy high byte to result iladc_val <<= 8; // shift low byte to 2nd byte iladc_val |= ADRESL; // OR result with ADRESL to get both the bytes into one var. Delay100TCYx(200); dladc_val = (float)iladc_val; dladc_val = dladc_val * 0.0048875855327468; float2string(dladc_val); } void lcdinit(){ lcdcmd(0x0E); // display and cursor ON.Writing 0x0F makes the cursor blink MSDelay(15); //delay lcdcmd(0x01); // this is to clear LCD MSDelay(15); lcdcmd(0x06); // shift the cursor to right MSDelay(15); lcdcmd(0x80); //line 1, position 0 MSDelay(1); } void lcdcmd(char value) { ldata = value; // put the value on the pins of PORTD rs = 0; rw = 0; en = 1; // strobe enable pin MSDelay(1); en = 0; } void lcddata (char value) { ldata = value; //put the value on the pins of PORTD rs = 1; rw = 0; en = 1; // strobe enable pin MSDelay(1); en = 0; } void lcdstring(unsigned char *lcd_data){ unsigned char cllcd_data; while(*lcd_data){ cllcd_data = *lcd_data; lcddata(cllcd_data); lcd_data++; } } void MSDelay(int itime) { unsigned int i,j; for(i=0;i<itime;i++) for(j=0;j<135;j++); } void main(){ TRISA = 0x01; PORTA = 0x00; LATA = 0x00; TRISB = 0x00; PORTB = 0x00; LATB = 0x00; TRISD = 0x00; PORTD = 0x00; LATD = 0x00; ADCON0 = 0x00; ADCON1 = 0x0E; ADCON2 = 0xB6; CMCON = 0x00; lcdinit(); while(1){ adc_read(); if(dladc_val != old_val){ lcdcmd(0x01); Delay100TCYx(50); lcdcmd(0x80); Delay100TCYx(50); lcdstring(&myString); for(i = 0; i < 9; i++){ if(myflt == V[i]){ ctr++; if(ctr > 0){ PORTBbits.RB7 = 1; } else{ PORTBbits.RB7 = 0; } } } ctr = 0; myflt = 0.0; old_val = dladc_val; } } }
