Can Quartus II convert VHDL code to a schematic?
winglj
Full Member level 4
Hi, everyone. I have a question about convert VHDL code to a schematic. Can Quartus II complete this job? or any other softwares can do so? Thanks.
It can generate an RTL schematic and you can go look at how the design is implemented.
Another tool which maybe of interest is HDL Ease, it can take VHDL and create block diagrams of a design.
- Jayson
    winglj
Can qu(at)rtus II convert VHDL code to a schematic?
After writing ur coding, simulate then from tools menu choose RTL viewer. u can check ur schemativ there and also the FSM
Yes it does.. Just create the component..
Ya, u can convert VHDL code to schematic.After writing the VHDL code in the quartus II software,compile it.After it is compiled successfully,go to the file menu in which there is create/update option.Select "create symbol files for the current file" option and the block diagram will be automatically generated.
