CAN protocol on PIC18F458 help!
chip_123
Newbie level 2
b
Hi
I am trying to work on Can bus project with PIC 18F458 and MCP2551.
I have done loopback mode successfully on pic demo board .
I have mounted CAN bus ckt with MCP2551 on bread board.
Now my CAN bus transmission is not working.
it got stuck in while(TXB0REQ);
i think my CAN bus is not working or not properly mounted????
Is any one has breadboard implementation of CAN BUS???
Any pic?:roll:
help me.
skogsjanne
Full Member level 3
One popular mistake when getting started with CAN is to try to run it with only one node on the bus. You need at least two nodes.
I'm no fan of Microchip but I think you will find answers to most of your questions in their documentation.
chip_123
Newbie level 2
here is the thing.
I hav two PIC18F458 IC with two transreceivers MCP2551.
My aim is to transfer data from one pic to another using CAN.
I hav config one pic for transmission and another for reception. between two there is can bus.
my prog works fine in loopback mode.
but when tried in normal mode transmission it gets stuck for transmission request. i.e. while(TXB0REQ);
i.e . Bus is not available for transmission.
I checked all voltages and found to be correct.
CANH=CANL=2.5v
resistance betn CANH and CANL is 60 ohm.
i don't understand where the prob is?
skogsjanne
Full Member level 3
OK, at least you haven't made the mistake to have only one node.
I'm sorry, but I don't think I can help any more since I have no experience with CAN + Microchip.
My only advice is to read the documentation from Microchip. And check for silly errors :eek:)
raowakeel
Junior Member level 3
pakistan
have you done this??then help me i want to do the same project
