priya ravichander
- Joined
- Aug 15, 2013
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 69
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 void main() { unsigned char temperature, data[8]; unsigned short init_flag, send_flag, dt, len, read_flag; char SJW, BRP, Phase_Seg1, Phase_Seg2, Prop_Seg, txt[4]; unsigned int temp; unsigned long mV; long id, mask; TRISA = 0xFF; // PORTA are inputs TRISB = 0x08; // RB2 is output, RB3 is input // // Configure A/D converter // ADCON1 = 0x80; // // CAN BUS Timing Parameters // SJW = 1; BRP = 1; Phase_Seg1 = 6; Phase_Seg2 = 7; BRP = 1; Prop_Seg = 6; init_flag = CAN_CONFIG_SAMPLE_THRICE & CAN_CONFIG_PHSEG2_PRG_ON & CAN_CONFIG_STD_MSG & CAN_CONFIG_DBL_BUFFER_ON & CAN_CONFIG_VALID_XTD_MSG & CAN_CONFIG_LINE_FILTER_OFF; send_flag = CAN_TX_PRIORITY_0 & CAN_TX_XTD_FRAME & CAN_TX_NO_RTR_FRAME; read_flag = 0; // // Initialise CAN module // CANInitialize(SJW, BRP, Phase_Seg1, Phase_Seg2, Prop_Seg, init_flag); // // Set CAN CONFIG mode // CANSetOperationMode(CAN_MODE_CONFIG, 0xFF); mask = -1; // // Set all MASK1 bits to 1's // CANSetMask(CAN_MASK_B1, mask, CAN_CONFIG_XTD_MSG); // // Set all MASK2 bits to 1's // CANSetMask(CAN_MASK_B2, mask, CAN_CONFIG_XTD_MSG); // // Set id of filter B1_F1 to 3 // CANSetFilter(CAN_FILTER_B2_F3,500,CAN_CONFIG_XTD_MSG); // // Set CAN module to NORMAL mode // CANSetOperationMode(CAN_MODE_NORMAL, 0xFF); // // Program loop. Read the temperature from analog temperature // sensor // for(;;) // Endless loop { // // Wait until a request is received // dt = 0; while(!dt) dt = CANRead(&id, data, &len, &read_flag); if(id == 500 && data[0] == 'T') { // // Now read the temperature // temp = Adc_Read(0); // Read temp mV = (unsigned long)temp * 5000 / 1024; // in mV temperature = mV/10; // in degrees C // // send the temperature to Node:Display // data[0] = temperature; id = 3; // Identifier CANWrite(id, data, 1, send_flag); // send temperature } } }
get me the header for this program and compiler to be used for this program
