Can please anybody tell me why this code doesn´t work proper
juanma21
Newbie level 6
The part that is not correct is after fmult, please!! I've been days trying to figure out why it isn't working????
# main.s
# Tests the operation of of the fmult function by comparing its result
# to that of a mul.s instruction.
.text
.globl test
# Tests the fmult function.
# 1st parameter (a0) single precision floating point multiplicand
# 2nd parameter (a1) single precision floating point multiplier
test: addi $sp, $sp, -16 # make space on stack
sw $ra, 0($sp) # preserve return address
sw $s0, 4($sp) # preserve registers s0 through s2
sw $s1, 8($sp)
sw $s2, 12($sp)
move $s0, $a0 # save multiplicand in $s0
move $s1, $a1 # save multiplier in $s1
jal fmult # call multiplication function
move $s2, $v0 # save result in s2
mtc1 $s0, $f12 # parameter = multiplicand
li $v0, 2 # load the "print float" syscall number
syscall
la $a0, str1 # parameter = str1
li $v0, 4 # load the "print string" syscall number
syscall
mtc1 $s1, $f12 # parameter = multiplier
syscall
la $a0, str2 # parameter = str2
syscall
mtc1 $s0, $f2
mtc1 $s1, $f4
mul.s $f0, $f2, $f4 # multiply
mov.s $f12, $f0 # parameter = product
syscall
la $a0, endl # parameter = endl
syscall
la $a0, str3 # parameter = str3
syscall
mtc1 $s2, $f12 # parameter = product
syscall
syscall
lw $ra, 0($sp) # restore return address
lw $s0, 4($sp) # restore registers s0 through s2
lw $s1, 8($sp)
lw $s2, 12($sp)
addi $sp, $sp, 16 # restore stack pointer
jr $ra # return
.globl main
# Checks multiple test cases
# then prompts for input of additional test cases.
main: addi $sp, $sp, -12 # make space on stack
sw $s0, 4($sp) # preserve registers used by this function
sw $s1, 8($sp)
la $s0, f1 # address of first floating point number
la $s1, fn # address of last floating point number
loop1:
lw $a0, 0($s0)
lw $a1, 4($s0)
jal test
addi $s0, 4
bne $s0, $s1, loop1
loop2:
la $a0, prompt # parameter = prompt
syscall
li $v0, 6 # load the "read float" syscall number
syscall
mfc1 $s0, $f0 # s0 = floating-point multiplicand
syscall
syscall
mfc1 $s1, $f0 # s1 = floating-point multiplier
move $a0, $s0
move $a1, $s1
jal test
j loop2 # loop forever
li $v0, 0 # return value
lw $s0, 4($sp) # restore registers used by this function
lw $s1, 8($sp)
addi $sp, $sp, 12 # restore stack pointer
jr $ra # return
.data
# Test cases:
# Check all 4 combinations of signs
# Check zero as either operand (or both)
# Check one as an operand
# Check normalization of results with 01, 10, 11 to left of binary point
# Check for exponents greater than 1
# (so that there will be overflow for intermediate biased exponent)
# Check for results with even and odd exponents
# Check for negative exponents
# Check result with 1 in least significant bit
f1: .float 1.0 # 1.0000 x 2^0
.float -2.0 # -1.0000 x 2^1
.float -5.0 # -1.2500 x 2^2
.float 12.0 # 1.5000 x 2^3
.float -14.0 # -1.7500 x 2^3
.float 0.0
.float 0.0
.float 62.0 # 1.9375 x 2^5
.float 112.0 # 1.7500 x 2^6
fn: .word 0xBE000004 # result will have 1 in least significant bit
prompt: .asciiz "Enter a floating-point number: "
str1: .asciiz " multiplied by "
str2: .asciiz " is "
str3: .asciiz "Your answer was "
endl: .asciiz "\n"
# float.s
# floating-point multiplication
.text
.globl fmult
# Preconditions:
# Postconditions:
# result (v0) single precision floating point product
fmult: li $v0,0 # v0 = 0, the default result
beq $a0,$zero,fmult # return if multiplicand is zero
beq $a1,$zero,fmult # return if multiplier is zero
# place mask for leftmost bit in t5
li $t5,0x80000000 # t5 = 0x80000000
# place sign of multiplicand in t0
and $t0,$a0,$t5 # mask off exponent and significand
# place sign of multiplier in t1
and $t1,$a1,$t5 # mask off exponent and significand
# place sign of product in t2
xor $t2,$t0,$t1 # t2 = xor of signs
# place exponent of multiplicand in t0
sll $t0,$a0,1 # shift to remove sign bit
srl $t0,$t0,24 # shift to remove significand bits
li $t6,127 # subract exponent bias
sub $t0,$t0,$t6
# place exponent of multiplier in t1
sll $t1,$a1,1 # shift to remove sign bit
srl $t1,$t1,24 # shift to remove significand bits
li $t7,127 # subract exponent bias
sub $t1,$t1,$t7
# place exponent of product in t3
# ignore the possibility of overflow or underflow
add $t3,$t1,$t0 # t3 = sum of exponents
addi $t3,$t3,127 # add exponent bias
# place significand of multiplicand in t0
sll $t0,$a0,9 # shift to remove exponent
srl $t0,$t0,9
li $t5,0x00800000 # restore implicit 1 to left of significand
or $t0,$t5,$t0
# place significand of multiplier in t1
sll $t1,$a1,9 # shift to remove exponent
srl $t1,$t1,9
or $t1,$t5,$t1 # restore implicit 1 to left of significand
# place significand of product in t4
# ignore rounding and overflow
multu $t0, $t1 # multiply significands (unsigned)
mfhi $t4 # t4 = high word of product
bge $t4, $zero, norm # branch if already normalized
srl $t4, $t4, 1 # shift significand to normalize
addi $t3, $t3, 1 # adjust exponent
norm: sll $t4, $t4, 2 # shift to remove implicit 1
# assemble product in v0
sll $t3, $t3, 23 # shift exponent into proper position
srl $t4, $t4, 9 # shift significand into proper position
move $v0, $t2 # place sign in v0
or $v0, $v0, $t3 # place exponent in v0
or $v0, $v0, $t4 # place significand in v0
return: jr $ra # return
