Can PIC16F877 do floating point math?
stevenlkz
Newbie level 3
microchip an575 picfloat
Hello everyone! Im doing my final project about intelligent traffic system with fuzzy logic that need to build into PIC16F877. But I face a problem that is there are no multiply, divide, square and square root instruction with MPlab. Another problem is I need to do the math in floating point. How can I solve it? Any advices and suggestions do u all can give me?
Thanks for spending your time.
C-Man
Which programming language are you using??
Please state wheter you program in assembler, basic, c ...
best regards
aym_qunibi
Member level 4
i am sorry it is not the compiler ,but the file size i want to send to you is very large
so send me your email and i will send it to you by parts.
:eek:
    stevenlkz
GrandAlf
Advanced Member level 2
UK
Most small MCUs do not have an FPU unit due to various constraints. If you are using C there is probably a FP library available. Not very efficient though, it will cost speed and memory.
stevenlkz
Newbie level 3
Im using the MPlab, which is an assembler. I must use the floating point for my fuzzy logic.
VVV
Advanced Member level 5
Check out Application note AN576 (I think) from Microchip. It gives details on implementing IEEE-754 compliant floating point routines. (If it's not AN576, try AN575. The Microchip website is down right now, so I could not check).
comsians
Member level 1
yes, PIC16F877 has a floating point math i know because
in my final project i am using this microcontroller but using a compiler of
WIZ-C which provide the fascility of
floating point math
u can check the software at
wizc.co.uk/fored
muruga86
Member level 3
Chennai, India
if u are using an assembler u have to implement floating point algoritham urself, or else if u use any c compiler ther will be build in libraries that take care of floating point operations. flaoting point operations require more instructions to execute. mostly the micro clock determines how fast floating point operations takes place and jence if ur clock freq. is too small then micro an't complete it.
