T
treez
Hello,
I am using an OPA335 opamp as a differential amp with a gain of 100....
...sometimes the input signal will only be 500uV, which would mean an output voltage of 50mV , which is lower than the 100mV minimum achievable output voltage when the OPA335 opamp has a single supply.
.....If i use the LM7705 to supply the opamps "V-" terminal, then will i be able to attain the 50mV output voltage?
LM7705 datasheet
https://www.ti.com/product/lm7705&lpos=Middle_Container&lid=Alternative_Devices
OPA335 Datasheet
https://www.ti.com/lit/ds/symlink/opa335.pdf
LM7705 datasheet
OPA335 Datasheet
