Can linux be used as real time operating system ?
raja.bhavanam
Junior Member level 3
linux as RTOS
can we use linux as real time operating system ?
dipal_z
Full Member level 5
India
linux as RTOS
No, as it is you can't use it for real time applications because the scheduling in Real Time operating system is different which provides guaranteed processing time/resources for each task.
But there are some linux kernels available with real time scheduler. Check out https://www.fsmlabs.com/index.php for details.
pengyou54
Newbie level 5
linux as RTOS
as far as I know, the new linux kernel at least later than 2.6 can be used to do it. However, you should double check it!
prd
Member level 3
Re: linux as RTOS
There are 2 well known linux patch for real-time application
Try www.rtai.org for RTAI and www.fsmlabs.com for RTLinux
Also try google to see the document compare this two alternatives
jhonny_yang
Full Member level 2
Re: linux as RTOS
prd said:
There are 2 well known linux fix for real-time application
Monta Vista , Real Time Linux, uCLinux etc and so much now. try to search. Some of them said the linux is not good for RTOS too big. but the capability and expanbility is very good
praveenbarupati
linux as RTOS
use rtai-3.5 with linux kernel 2.6.19 it works
