Can ISR call semaphore?
naresh850
Full Member level 3
Full Member level 3
isr semaphore block
Hello
Regards,
NP
isr and semaphore
You can't call an semaphore from within an ISR. Taking a semaphore is a blockable operation. The rule of thumb is, when in an interrupt do not block.
ISR can only send Messages and can only release a semaphore.
can isr take semaphore
An ISR can do only non-blocking calls.
I.E.
An ISR can put an event into mail box without blocking.
NOTE.
Is very important for an ISR to spent small time to complete her operations.
call semaphore from isr
it is not advisable to call semaphones from ISR's
semaphore in isr
In most cases you can raise a semaphore from ISR but can not pend on it. Check your RTOS documentation.
