Hello
I have written a simple program to receive CAN messages using the CAN1 interface. If I burn the monitor in Flash and I run the program, it works, but if I burn the program in Flash, it doesn't work. Does anybody know why?
I have tested the Start167.asm file and I think all is correct. The variables are correctly put in the memory.
I am using MCB167-NET, with a C167CS-LM.
I want to burn my program in a external Flash. First, I burned the monitor in the external Flash and the program worked correctly. This is, it read the CAN messages and sent the received data via 232 interface.
When I burn this program in the external Flash, it doesn't work; I can see (using the leds connected to P2) that the CAN interrupts are being activated, but the data receaved are incorrect.
I think you are right and the mistake should be at the startup program, but I cannot find the mistake.
can anybody help me?
Thank you
