milan.rajik
Banned
Can I use the circuit provided here ? Will this work. I have seen some poor quality SIM900 boards which give garbage data sometimes on UART lines.
I want to make sure if this board works. I will be making some modifications. The board will have only connections for
PWRKEY
nRESET
RF Ant
Net Light
RxD
TxD
GND
Vcc
SIM holder
The same components mentioned at the above page will be used but I need it to work from a 3.7V Li-Po battery and the Vcc has to be 3.3V. So, can I use a LM1117 LDO regulator to provide 3.3V from 3.7V ? Can LM1117 SMD version can provide 2A current needed while sending SMS ? If it is better to use any other kind of power conditioning circuit then please provide a sample circuit.
I will also be using 3.3V interfacing method.
https://www.open-electronics.org/small-breakout-for-sim900-gsm-module/
If anybody can provide a better all SMD circuit with component list then it will be helpful. I want to integrate a PIC32MX270F256D TQFP chip with SIM900 and make a small board for SMS alerting system. There will be a Li-po charger circuit on-board and also I need a circuit for providing 3.3V from 3.7V 6600 mAh Li-Po.
I am planning to make the board not more than 6.5 cm X 4.5 cm x 1.6mm.
Can I use the DC-DC power supply provided here http://electronics.stackexchange.com/questions/123240/powering-sim-900-gsm
to provide 3.3V to SIM900 from 3.7V Li-Po ?
PWRKEY
nRESET
RF Ant
Net Light
RxD
TxD
GND
Vcc
SIM holder
