Hi all, I just wonder if I can use a relay to enable/disable a PS/2 mouse and keyboard operation. For example, I want to disable them from being used during the time under Windows running, and probably re-enable it afterwards.
There are 6 pins in PS/2 as in:
1 - Data
2 - Not Implemented
3 - Ground
4 - Vcc (+5V)
5 - Clock
6 - Not Implemented
I'm not sure which pin I can use to enable/disable its operation.
Are you sure? Seems strange that you are asking a question and correcting others at the same time.
Anyway, I've plugged and unplugged my mouse/keyboard hundreds of times while the PC is running ... works fine so far.
PS/2 mouse has to be connected to the PC at boot time, else it won't get detected.
Connecting/disconnecting during operation usually works, but is bad practice.
Better get USB keyboard and mouse (or a PS/2 --> USB protocol converter).
What I'm trying to do is disable the PS/2 mouse and keyboard when some conditions are fulfilled. For example, when time's up, the keyboard and mouse will be disabled (locked) using hardware method so that user cant use them temporarily until another condition is fulfilled later. I managed to disable them now by cutting the DATA or CLOCK line during the operation when Windows is running and they can be resumed after I connect back the line! However, I'm not sure if I need to cut both DATA and CLOCK lines or just either one of them?
Why DATA only? I dont agree with u.
I just did some experiments on the PS/2 keyboard. I found that even if I disconnect the DATA line but still pressing something on the keyboard, when I connect back the DATA line, I'll still get the things that I typed when the DATA line is not connected. So I guess it would be better to disconnect the CLOCK line rather than the DATA line.
Because while in operation, Keyboard will send synchorocouns and DATA to PC, so if you only cut data line, your pc still receive DATA, too. But sended DATA is wrong DATA.
