can I use P0 as a port, data and address at once ?
bianchi77
California
Hello guys,
At 89S52 chip
I need P0 for addressing, receive data from Flash and use it as data port to TFT LCD,
Is it possible ?
Thanks
Basically, Po can be used in a triple function:
- bus data (accessed during MOVX instructions)
- multiplexed bus address 0 to 7 (latched by ALE)
- as open drain port pins.
Your application needs to consider the fact, that the P0 output state is temporarily changed during bus accesses. Also the peripherals connected to the port must not short the bus.
How can I share it in code ?
89S52 will take my code from 29C512 but I want to use the AD0-AD7 as a P0-P7 as well as a controller for TFT...
I have tested that that 89S52 has be able to read my code in 29C512....
How can I use AD0-AD7 as P0.0 to P0.7 for my TFT ?
Any info will be appreciated..
Thanks
Depends on how the P0 TFT interface is used in your code.
Is it possible if I put like this :
tft MCS51 port
d0-----------P0.0
d1-----------P0.1
d2-----------P0.2
d3-----------P0.3
d4-----------P0.4
d5-----------P0.5
d6-----------P0.6
d7-----------p0.7
The question isn't about the pin assignment rather than about the interface functionality and timing. Does it tolerate the temporary level transitions during flash read? Can it possibly be operated as a data bus interface controlled by WR?
There may be a conflict during flash read, that's what I'm thinking, but I need more memory next time.
I have two options in my mind, modify the circuit or the code...
Do you have any suggestions ?
Do you want to see the circuit diagram ? I'll send you via email...
If you don't mind, you can tell me your email address at private message,
Thanks
