Yes if you switch to VOIP then you could route whole telephone traffic over the same fiber optic cable used for internet.leoren_tm said:is it posible to use fiber optic cable use for internet in our campus
to be able to use also on our telephone system???
utilizing it...
can you pls explain VOIP?????sinip said:Yes if you switch to VOIP then you could route whole telephone traffic over the same fiber optic cable used for internet.leoren_tm said:is it posible to use fiber optic cable use for internet in our campus
utilizing it...
VoIP stands for "Voice over IP". Go to Google and do some search on the subject.leoren_tm said:can you pls explain VOIP?????sinip said:Yes if you switch to VOIP then you could route whole telephone traffic over the same fiber optic cable used for internet.leoren_tm said:is it posible to use fiber optic cable use for internet in our campus
utilizing it...
do i have other choice????sinip said:VoIP stands for "Voice over IP". Go to Google and do some search on the subject.leoren_tm said:can you pls explain VOIP?????sinip said:Yes if you switch to VOIP then you could route whole telephone traffic over the same fiber optic cable used for internet.leoren_tm said:is it posible to use fiber optic cable use for internet in our campus
utilizing it...
utilizing it...
