Can I use different kinds of MOSFETs in one circuit (.18 CMOS process)?
berryfan
In .18 process,there are some kinds of mosfet,for example,mos in 3.3V ,mos in 1.8V,can I use them in one circuit.thanks!
.18 cmos question
Sure, you can use it in one circuit.
3.3V mos has thick oxide.
.18 cmos question
thanks very much!
but can it affect the other mos 1.8V,because the process of them isn't same,so I'm afriad of the simulation result.
.18 cmos question
As long as I know, there's no effect if you obey design rules.
.18 cmos question
thanks a lot ljy4468
.18 cmos question
Any PDK has at least 2 types of transistors: core and I/O , in this case 1.8 transistors are for core, and 3.3 for I/O ( transistors that are connected cu I/O pads ). Usually when you have to interconect thoes two, you use a level shifter.
.18 cmos question
obi1,level shifter,you mean that 3.3V mos should use under 3.3V.so I must make the 1.8 up to 3.3 through a level shifter,then ,I can use 3.3V under 3.3V.
Re: .18 cmos question
Of course can.
3.3V and 1.8V means the power supply of the mosfet.
.18 cmos question
but it have not any affect?I still doubt it.because the process of making it is different.
Added after 5 minutes:
by the way,how many the simulation parameters of regulator are there?thanks.I mean all parameter we should concern.
just a quick glance of this thread.
i guess to convince yourself, you should run simulation and check if any of the devices are breakdown.
For LDO, there are quiet a few parameters need to be considered, such as load regulation......
I also think you can
.18 cmos question
you can. the other concern is cost. more device means more cost.
