Can I use DC adaptor instead of AC adaptor for camera?
Dantoc
I have adaptor camera that use a AC adaptor : 9V and 700mA
Can I use an other DC adaptor 9V and 1000mA
Pls help I'm just very begining
alvarorahul
Very beginer
i think so
the current 1000mA is the rating i.e. max current that the adapter can handle
eng_Semi
Full Member level 6
Egypt
Re: Very beginer
If u care on ur camera, so don't try with it.
I think that u couldn't use it
echo47
Advanced Member level 5
USA
Very beginer
alvarorahul, you may have overlooked that one is AC and the other is DC.
I wouldn't try it without first opening up the camera and studying its power input circuitry to see if would tolerate DC. That may be a difficult chore, so I would probably go buy the proper power unit.
scorpionss22
Full Member level 2
Very beginer
if u mean the two adapter is DC so there is noproblem
and if u mean that one is DC and the another is AC
so dont try that its better to contact the manfacture
and ask go to there website and ask them
MRFGUY
Full Member level 1
Re: Very beginer
I think camera adaptor should be DC adaptor. If so, the second adaptor max current is higher than your one, you can use 9V1000mA for 9v700mA.
If camera adaptor is AC adaptor you can't try.
Dantoc
Re: Very beginer
@ MRFGUY It's exactly is AC adaptor ( I checked in manifacture web site) Before I used a DC9V 800mA and It's working. ( may be have retifier inside ).So I can use DC 9V 1000 mA for this , right?
awan
Los Angeles
Re: Very beginer
USE A SMALL DEVICE IN PARALLEL WITH THE CAMERA BUT MAKE SURE IT DOESNOT CAUSE LARGE CURRENT DROP
power-twq
Full Member level 6
Re: Very beginer
no any problem, the latter will be better than the form one.
best regards
banh
Advanced Member level 1
Re: Very beginer
sure can. the rating 1000ma means the adaptor can withstand load upto 1000ma.
Kral
USA
Re: Very beginer
"Wall warts" fall into 2 categories; AC and DC. The AC types are simply transformers. The device under power provides its own rectifier, and possibly a filter. The DC types can have either - or + polarity. They have built-in Rectifiers, and sometimes have built in filters.
The following situations are based on the assumption that the new wall wart has the same voltage rating as the original.
Situation 1: The camera is designed for use with an AC wall wart:
. If the new (DC) wall wart has the wrong polarity, it won't work, but won't harm the camera
. If the new (DC) wall wart has the correct polarity it will work if its current rating is equal to or greater than the original wall wart.
Situation 2: The device is designed for use with a DC wall wart:
. If the new wall wart has the wrong polarity, you will fry your camera.
. If the new wall wart has the correct polarity and its current rating is equal to or greater than the original wall wart, then it will work.
. If the original wall wart is a DC type, and has a filter, as well as a rectifier, the new wall wart may produce eratic results, if it has no filter or its filtering is not as good as the original, you may get erratic results from the camera, but no damage will be done.
