Advark
Member level 3
- Joined
- Feb 22, 2008
- Messages
- 66
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- POA, Brazil-RS
- Activity points
- 1,684
mahaju said:hi
you will need opamps with frequency response range (to the range of 100s of MHz). I dont think such opamps will be easily available, but of course it depends on what resources are available at your location.
Advark said:Hi i have a doubt can i use a active inductor based on a gyrator for RFIC
foxclab01 said:I am trying to replace a classic LC circuit with a gyrator or any active inductor ( so that I get rid of the passive inductor ).
The problem is that I want to use the circuit for high frequences. To be more specific, I want to use it as a filter that only allows a 38.9 Mhz frequency to pass and stops all the others.
Is there a way to do it? Is the noise ratio good? Is it possible to get a schematic?
foxclab01 said:........I have figured out the schematic that I attach. But I want to replace the 2 LC circuits that filter the video and audio with some active circuit ( not necessarily gyrators ).
On the other hand, the passive LC circuit seems to have a better behavior as a filter ( more accurate ).
