Hi, i am thinking of making a circuit that will use a Li-ion 3.7v battery and use it on a mp3 player that originally uses an AAA battery. If i use resistors in the circuit to drop the 3.7v to 1.5v will the power dissipated in the resistors be significant? Will the Li-ion battery actually last longer than an AAA battery? Also do I need to concern about the currents?
depend how much curret unit draw. but you always waste energy 1.5 Volt -> 3.7 Volt to heat and only using 30-40 % of batterys total energy capacity if only using linary regulator (or resistance if current is very constant with using) to take down voltage.
but 3.0-4.0 Volt is very attractive if you want more power to eraphone amplifier for louder soundlevel without clipping...
possibe to find couple of circurits to convert 3.0-4.2 Volt from LiIon-battery to 1.5 Volt without so much loss.
See maxim, Analog device, and nationa semicontctor etc.
You can try to make a switching mode power supply(DC - DC convertor) by yourself with chip comes from ST or Linear Technology and few passive components. It's effiency is can reach up to 85% or even higher.
