can I use 16-bit adder as 2 seperate 8-bit adders?
omara007
Cairo/Egypt
16 bit adder
Is there any adder architecture that supports this ? ..
if so, is there a Synopsys DW that implements it ? ..
16 bit adder from 8 bit
yep ,i think u can re-design the 16bit add into a 2 8-bits add in RTL.
16-bit adder using 2 8-bit adders
if you want to use two 8-bit adders, you use the adder with carry bit.
1, lower 8 bits add together. get the low carry bit
2, higher 8 bits add with the low carry bit. the result will be 17bit if you care the carry.
Does this work with signed numbers ??
