bwinter88
Newbie level 6
Hello there,
I am reconditioning a friend's Philco radio from 1965 to work in FM instead of AM, and want to preserve the functionality of the mechanical tuning and preset buttons. This requires me to construct a whole new FM circuit.
No problem. I like the looks of the TDA7021 chip with a TDA7040 stereo decoder, and I know I have to retune the IF to around 10.7 MHz to be ideal for FM receiving. The chip, according to the datasheet, is shown to use a variable capacitor to tune the resonant frequency...but.
The Philco radio uses a variable coil (inductance) to tune between stations, not variable capacitance. But should this matter? Obviously the time constant has to come out the same, but does it matter which way I get there?
My plan is this: measure the range of inductance that the Philco coils can achieve, then calculate the required C value to get the LC constant to that of FM reception.
Would this work? My worry is that variable coils are not accurate enough to tune in FM. The datasheet describes using the inductor value to select the range of frequencies (FM/LW/SW), and then using the varicap to scan stations, which makes me think inductors are for rough adjustment only.
