Can I revert the copper areas in PowerPCB at once ?
davorin
Advanced Member level 3
Switzerland
Copper areas in PowerPCB
Is it possible to revert the copperplanes at once in powerpcb?
Hard to delete all little islands by hand after opening an existing design with pour manager applied (o;
setup-preferences-thermals
select remove isolate copper
Re: Copper areas in PowerPCB
Nope...doesn't remove the created outlines....
use modeless command "PO"
you'll see cooper pour outline select shape and delete it
That's what I'm doing now...select shape by shape and delete it (o;
From Menu: select Edit --> Find...
In "Find By" pulldown select "Isolated Pour"
then delete selected shapes
take care while usiing the copper pour.
the file may get corupted if some thing go wrong.
like database fail.this may make the job file not to load again. keep a backup also check the integrity of the database by typing "i" and enter. before make a save
binu g
