[SOLVED] can i program 8951 by usin usb avr programmer
You can only program 89c51 if that programmer and software support 89c51 programming. Check the supported ICs list. (89C51 need parallel programmer.)
READ RULES BEFORE POSTING
SEARCH BEFORE POSTING
There is a sticky topic in the first page of microcontroller section
can i program 89s51 by using this AVR Usb programmer
YES. It all depends on the firmware in your programmer. If the firmware is the version that supports 89S51/89S52 then it will work. If not, you can load the firmware in the atmega8(on the programmer) yourself.
get the code here:
Sir i don't know which firmware had on it .how can i understand ?
thanks in advance
