can i measure AC voltage with a mcu with only resistance?
xxtigerxx
Advanced Member level 1
Greece
mcu measuring ac frequency
ac voltage amplitude mcu
You can divide AC voltage to, say +/-2.5V, then add +2.5V offset, so the voltage that is fed to microcontroller is 0-5V ..
Regards,
IanP
Re: can i measure AC voltage with a mcu with only resistance
You can not measure directly AC voltage if use only the MCU and resistance (without ADC).
yes. if you have high voltage such as 110v or 220v you must first reduce it.
and if you don't have ADC and you want to use mcu adc, you must have an offset DC valtage.
you can use AVR MCU such as ATMega32 or ATmega16 Or Atmega8.
in this case, we used the ADC buit in with MCU.
without aux. ADC or built-in ADC it seems not possible. Bu as a theory, if you know the frequency of AC signal, you can make a R-2R ladder to create a DAC synchrosed with your test signal at zero-crossing. By changing amplitude of DAC output and adding it to test signal, you can find the AC amp. up to 4.7 volts.
