JohnJohn20
Hi. I just put a PCI Express graphics card in my computer and now the computer won't even start, just makes a buzzing sound.
I am told this is due to the existing 400 watt PSU is too small. Rather than fork out for a high wattage PSU, can I get another similar PSU and either:
1. Connect the 4-pin Peripheral power connector feeds (yellow 12V, red 5 V and two black grounds) together in a parallel fashion, and use this to power the computer.
2. Just run the PCI Express graphics card (which is powered by a seperate 6-pin connector rather than through the mainboard connector) off the new PSU while the rest of the computer is powered off the original PSU.
In this case, would it be advisable to connect the ground wires (the two black wires) of the two PSUs 4-pin Peripheral power connector feeds together to keep the 0V feeds the same?
Thanks.
Thanks.
