Can I burn hex file on PIC which was compiled with no linker file in MPLAB 8?
simonwai999
hi guys
i used mplab 8.0 with NO LINKER FILE in my project
and complied ok - got a hex file
( coz when i used the linker file MPLINK 4.14,these showed
Linker
Copyright (c) 2007 Microchip Technology Inc.
Error - section '.org_0' can not fit the absolute section. Section '.org_0' start=0x00000000, length=0x0000006c
Errors : 1
Link step failed.
BUILD FAILED: Wed Jul 16 21:13:29 2008
my question is can i still use that hex file to burn into my PIC ?
Thanks a bunch
is the hex file ok?
You're not supposed to use absolute code "ORG x" with the linker. Don't add the linker and assemble, your hex file will be fine.
Re: is the hex file ok?
hi pal
got it
thanks
cheers
