I've found that when CST MWS 2006 works on Core duo (with 2 cores) CPU, the simulation will give wrong results if setting the option "Use parallelization up to 2 Processors".
Could someone offer me a solution?
Thanks.[/url]
Thank you for your reply.
I've re-installed it several times and the problem remains the same.
But when I choose "1 processor", the result is pretty good.
Thanks.[/url]
I have also 2processor machine (2x Opteron).
The load is usually around 60-70 percents for both processors. CST recommends to run 2 simulations together to utilize processors on 100%
Usually the load for two Intel processors around 30-40 percents, now I understand from you that CST optimized better to AMD processors. And to utilize processors on 100% I have to buy another license.
So the extra license pay to utilize two processors is for nothing.
