SeungminLee
Junior Member level 2
Hello,
I wonder if CC2500 could immediately transmit three 5kbyte/s data continously.
As soon as I convert analog signal to digital signal using ADCs, I want to transmit it to PC via CC2500.
It is a little ambiguous according to the datasheet, so I need advices from experienced developers.
I want transmitter 3 channel 5kHz-sampled data from Atmega attached board to PC: the total data will be 15kbypes per sec.
Can CC2500 speed up to this rate without non-operating term? All data should be contiounsly transmit to the PC.
