Can Cadence read Synopsys Tech. Library (.db) ?
omara007
Cairo/Egypt
cadence dbformat
I know that it can read (.lib) .. but I have synopsys's (.db) library and I don't know how to read it using SoC Encounter (RTL Compiler) ? .. and if that's feasible, what's the command ? .. and this can't be done directly, where can I find a converter ?
.lib cadence converter
Hi I dont think Cadence tools can read .db format. Its internal format for synopsys
what is synopsys .db library format?
The answer is NO.
RTL Compiler CAN NOT read in Synopsys's .db libraries.
Try to get the Synopsys Liberty(.lib) libraries from the library vendor directly.
synopsys .db format
Can the .db file be transfered to .lib file?
The .db can be transfered to .plib, but I don't know~! I will have a try tomorrow.
convert synopsys .db to .lib
No more discussion .db is cant read by Cadence tools.
Use library converter tool from synopsys for more help
Thanks
Aravind
synopsys db
Thanks
Aravind
seems that the library converter is a synopsys tool .. the problem is that I have cadence tools and synopsys libraries
convert synopsys db to lib file
I'm wondering how to translate/convert Synopsys .db libraries into Liberty(.lib) libraries ?
Use which tool/command from Synopsys ?
Thanks in advance.
