Can Cadence netlist schematic in SPICE form? How?
ahmad_abdulghany
San Jose, California, USA
netlist to schematic
I want to extract the SPICE netlist from certain Schematic that is drawn in Virtuoso Schematic Editor, can cadence do that? Or I can only netlist for Spectre?
Can I generate the netlist (whatever Spectre or SPICE) using SKILL?
Any suggestions?
Thanks and regards,
Ahmad
cadence netlist
If Spice is properly installed, you can.
1. In ADE (analog design environment) go to Setup>Simulator/Directory/Host... then select Hspice as your simulator and press OK (if you don't have that option then the tool is not properly set up).
2. Go to Simulation>Netlist>Create and that's it
Hope this helps,
diemilio
spice netlist schematic
R u trying to run simulation with Hspice for the netlist generated from cadence schematic entry??
if so.. here are the few addon's to comments from diemilio
While drawing the schematic you shld use Hspice View for the components so that netlister will do the netlist in Hspice format without any error.
In this not all Hspice elements are supported !! U can try latest Hspice which have some interface future which works well with cadence and it comes free with Hspcie.
Hope this helps.
Thanx
