Hicham M
Member level 1
- Joined
- Feb 1, 2014
- Messages
- 38
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 321
Hello,
I have a vehicle equipped with CAN bus, and based on it's schematic, this vehicle has many control units equipped with CAN bus, 2 control units have a 120 ohm resistor, which is normal.
I have a custom electronic board that has A CAN bus, and have a 120 ohms between CANH and CANL inputs of this board. I mounted this board on the vehicle and everything worked fine for couple of months before the driver started noticing some weird behaviours in the accessory controllers when my board is connected to the vehicle.
I discovered recently about this internal resistor, could this be the problem ?
And does anyone here knows how to diagnostic this kind of problems ?
thank you
thank you
