Register Log in
Can anyone tell me what is imp layer ??
mujju433
Full Member level 3
implayer
I want clear explaination on imp layer can anyone explain me ?
I know why we are using imp layer but i want "what is imp layer"
Fahmy
Full Member level 2
what is imp
If you are talking about integrated circuits, Do you mean implantation layer?
mujju433
Full Member level 3
imp layer
Yes i am talking about implantation layer
_i386sx25_
Member level 3
implant layer
IC fabrication starts with a certain type dopped of silicon substrate, lets say p type. To make transsitor on this substrate you need to create n type layer. To make it a certain type of ions implanted by using ion implanter into substrate.
It's better to read vlsi book to get more detailed explanation.
mujju433
Full Member level 3
Yes thats true but what is that implant layer ?? i have seen in many books but the explaination is not clear thats why i am asking here so anybody else can explain me ?
I know why we are using implant layer but i want to know what is imp layer i mean p imp and n imp
whats that imp layer ???
Fahmy
Full Member level 2
The implant layer defines the regions were the silicon is doped with impurities to form an n-type or p-type silicon . This implantation is necessary for the formation of source/drain regions , poly Si gates and bulk ties. The implant layer have higher importance when it intersects with the active area region (region with thin oxide) . because this intersection only defines the n+ or p+ regions which is used to create transistors and bulk ties . If the implant layer exists in a place where there is no thin oxide , the doping will be light and can not be used in S/D regions or ohmic bulk ties.
mohdfayez
Junior Member level 2
how important is implant layer when it comes to layout design of standard cells? Is implant layer a part of standard library? any other use of imp layer outside standard cell design?
Fahmy
Full Member level 2
implant layer is essential for any NMOS/PMOS transistor , bulk tie ,diodes and some types of resistors .
imlant layer must exist in standard cells or any custom-made layout.
Toggle Sidebar
