Can anyone tell how to design elliptic filter
shady205
Full Member level 2
India Bangalore
Hello friends...
Can you help me in designing an elliptic filter. I'm planning to do a switched capacitor Elliptic Ladder Filter for an order 5.
I had uploaded the passive structure and the corresponding signal flow graph.
Thanks in Advance
Bhagath
Added after 58 minutes:
uploaded files
Hi Bhagath,
in the following I can give you two references, which very good matches your problem. In both cases, elliptical S/C filters are designed based on a SFG diagram which is identical to yours.
1.) Jacobs, Allstot, Brodersen, Gray: Design Techniques for MOS switched capacitor ladder filters, IEEE Trans. Circuits ans systems, CAS-25, No 12, Dec. 78, page 1014
2.) Brodersen, Gray, Hodges: MOS Switched-Capacitor Filters, Proceedings IEEE, vol-67, No 1, Jan. 1979, page 61
Perhaps this helps.
LvW
    shady205
thanks LvW..
i do have those papers but what i need is ...
i found the Transfer function from the above passive network and i want to equate the corresponding Transfer function to the standard elliptic (lowpass ) prototype for passive elements.
by comparing these two for the same transition ratio and ripple we get the values of the corresponding L and C values. But i don't have the standard elliptic prototype for passive elements which is in the below following books..
R.Saal Handbook of filter Design AEG-Telefunen, Berlin 1979.
D.S.Sticht & L.P.Huelsman Direct determination of Elliptic network functions Int J. Comput Elec Eng Vol 1 pp 272-280 1973
A.L.Zverev Handbook of Filter synthesis Wiley New york, 1967.
if u have any information regarding the Elliptic prototype for passive elements just let me know...
Thanks
Bhagath
Hi Bhagath,
I can recommend a design program for passive filters (including elliptical response) to you which you can download for free:
Look at AADE.com
I hope this can help you designing the network
but i need to design in Cadence spectre..
and i need to design an analog elliptic Ladder filter
Now I am confused, cause I do not see your problem.
The program I have mentioned (AADE) gives you the values for the components (L, C and R) to be used in a ladder topologie and establishing an elliptical response.
What do you still need ?
LvW
i need to design an elliptic filter for the following specification..
Ripple = 0.4dB
Stop band gain = -36 dB
transition ratio (Fs/Fc) =1.25
Fc (Corner Frequency) = 40K Hz
Order = 5
Fs = 50K Hz
Fclk = 2.2M Hz
Enter all these data (excluding the clock) into the program AADE and it gives you the desired analog ladder structure.
Than, you have to convert it into a S/C network according to the procedure which is described, for example, in the documents I have mentioned before.
LvW
