[SOLVED] Can anyone name this switch?
alexan_e
Administrator
Greece
It is a three position rotary switch,
it is like Single pole, double throw (SPDT) switch but has 1 to 3 instead of 1 to 2 selector.
Alex
Reactions: tswift
    tswift
alexan_e
Administrator
Greece
These can also be called 1 pole 3 way, both names describe the same but this second way gives also the accurate description of "inputs" and "outputs"
so you can also find:
•1 pole 12 way
•2 pole 6 way
•3 pole 4 way
•4 pole 3 way etc.
Alex
tswift
Alex, I am having a hard time finding a rotary switch than I can use for this.
Would there be a better way of wiring this circuit up?
alexan_e
Administrator
Greece
I don't know the exact functionality of your circuit but your schematic shows three possible connections how can this be done differently?
Alex
tswift
It probably can not be done any other way. I just thought I would throw that out for any possible suggestions.
I have very limited space where I will install this and it needs to only have 3 positions on the switch as I most likely will not be able to see this but will have to go by "feel" of the switch.
Any ideas where I could get such a switch?
alexan_e
Administrator
Greece
You can find them in any any electronics store online or local.
also on ebay
it will probably have more poles or more positions.
The only alternative i can think of is one switch on/off and a second as a selector for 12v and break light.
What is the connection with the 12V, you have an output going to the power supply?
Alex
---------- Post added at 02:18 ---------- Previous post was at 02:07 ----------
ok, i think the 3 poles are the inputs and the one pole goes to your circuit,
so it is constant on, off, and light when brake is pushed.
djsfantasi
Boston MA
Single Pole Double Throw -Center off switch... You don't need a rotary switch... You might also be able to find a single pole, triple (or greater) throw switch that would work for you as well.
tswift
Excellent
so this should work?
Radio Shack
DPDT with Center Off Heavy-Duty Toggle Switch
Model: 275-653 | Catalog #: 275-653
alexan_e
Administrator
Greece
Yes a switch like this with 3 positions up(on1)-center(off)-down(on2) should do
Alex
