Can anyone give me a 12MHz crystal simulation model?
holddreams
Full Member level 6
Full Member level 6
Shanghai
I want to design a 12MHz crsytal circuit,
and I need the simulation model(R,L,C,C0),
can someone give me ?
Thanks.
Here's data for a 11MHz crystal that should give you starting figures to work with
LS = 0.02
CS = 1E-14
RS = 45
CO = 4E-12
Remember crystal circuits may take very long to start up in simulations due to the high loaded Q
    holddreams
LS = 0.02
CS = 1E-14
RS = 45
CO = 4E-12
Thanks.
Can you tell me where you get this model?
And how can I figure it out for 12MHz?
This data comes from a model in Multisim. Look at this post for information I posted on crystal models
    holddreams
I have the same question of the previous author.
Is the model I used be accurate as on the market crsytal?
And only using those equations to get the parameter R,L,C,C0?
THX.
It depends what you mean by accurate. Most crystals needs to be trimmed individually in a circuit by external components (phase lead or phase lag to get the frequency within a few Hz of the desired frequency), even if you use crystals from the same batch. Without trimming you can expect ± 2kHz error at 11MHz. Also long term accuracy and drift will depend on type of cut, temperature and crystal dissipation from amount of drive current through RS.
    holddreams
