[SOLVED] Can anybody help me about calibre PERC? (error message)
wiwikkk
Newbie level 2
I try MGC_HOME share files.
It show this message.
What happen??
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
-----                CALIBRE::PERC - INITIALIZATION MODULE                 -----
Performing global initialization ...
Initializing LVS ...
//  Applying licensing policy...
Initializing REPORT ...
--- CALIBRE::PERC INITIALIZATION MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 1/3/3  MALLOC = 31/31/31  ELAPSED TIME = 1
-----          CALIBRE::PERC  -  EXECUTIVE MODULE                           -----
LVS Netlist Compiler - Errors and Warnings
Error: Subcircuit "[COLOR="#FF0000"]PERC__TOP_DUMMY[/COLOR]" not found
ERROR: Layout could not be read.
Re: Can anybody help me about calibre PERC?
Seems the subcircuit "PERC__TOP_DUMMY" is listed in the netlist, but cannot be found in the search path.
Check your CALIBRE search path used for PERC.
Because the var directory are full. Empty this Var directory and run the example is OK.
