can anybody give me advice about analog circuit's simulation
batistuta
Member level 5
everyone, i am a fresh man at the analog circuit design, i have read Razavil's book
more careful, and get the structures about most circuit, but i am puzzled by simulation, i do not know how to start. as you know, after simulating the circuit, you will get further. so can anybody give me some advice? is there some books about them? or some papers. i use candence design tool.
thank you very much!
I think you can read some tutorials of Candence.
From a unix terminal, you type 'cdsdoc' to view all the documents of Candence. you can find sth you need there
You can start from the opamp simulation. there are a lot of examples in cadence doc
Re: can anybody give me advice about analog circuit's simula
You should first understand analog circuit working principle.
There is no better tutor than working on a real example!
Create a switch that drives a resistor.
Work on all possible simulations ( mostly transient).
Add a capacitor ( now you have a filter). Do the same.
Try now switched capacitor by implemnting a logic ( a pulse generator) driving the switch. Simulate
Move to a simple one stage CMOS OPAMP.
I believe you got the idea....
D.
hspice and eldo are good tools to use also, for analog designers, to use these tools skillfully is absolutely necessary.
