Register Log in
can any 1 tel me where the wrong in program ADC pic16f882 internal adc
parimi.ravikiran
Pune
unsigned int low_value, hig_value;
void main()
OSCCON=0X60; // INTERNAL CLOCK FREQ 4MHZ
TRISA=1; // ADC INPUT PORTA
TRISB=0; //ADC O/P PORTB FOR LOWER BITS (0-1) USING LEFT JUSTIFIED
TRISC=0; // ADC O/P HIGHER BITS (2-9)
PORTB=0X00; // make o/p ports clear
PORTC=0X00; // make o/p ports clear
while(1)
ADCON0=0b01000000; //AN0 SELECT , clk Fosc/8
ANSEL=0x01; // ANALOG HAS BEEN SELECTED
ADCON0=0B01000001; // CLK FOSC/8 , Analog channel AN0,ADC ON
ADCON1=0X00; // Vref use vss , vdd
PIR1=0X00; // clr interrupt flag
delay_ms(30); // wait for 4.67uS ACQUISITION MIN TIME
//ADCON0=0x41; //make adc ON--- (not used now)
//ADCON0=0B01000011; // to make adc start.-- (not used now)
//while(PIR1=0b01000000) // check for IF bit is set or not-- (not used now)
for(;;) {
//ADCON0=0x43; // initiate conversion on the channel 0 , go/done bit=1
ADCON0|=2; //set bit go =1
//while(GO); // Wait conversion done
//while(Go&0x00);
while(ADIF); //checking that go bit is clear or not . is conversion over?
portb=ADRESL; // send lower 2 bits 0-1 to portb
//portb=low_value;
portc=ADRESH; //send 2-9 bits higher bits to portc. msb last
//PORTC=hig_value;
PIR1=0X00; // clear IF( Interrupt flag)
btbass
Advanced Member level 5
Oberon
It is a lot easier to understand if you put the A/D conversion into a single separate function.
Divide and conquer!
This also promotes reusable code, once you have a peripheral function debugged and working, next time you need it, it's a cut and paste job.
/*--- Read A/D conversion ---*/
unsigned int read_ad(unsigned char channel)
  unsigned int result = 0U;
  unsigned char acquisition_time = 3U;
  ADCON1 = 0x80U;   /* 10 bit Right justified result, Vdd as ref */
  ADCON0 = 0x81U;   /* Conversion clock Fosc/32 */
  ADCON0 |= (unsigned char)(channel << 2U);  /* Select channel */
  while(acquisition_time--){ /* Sample channel */
  GODONE = 1U;    /* Start conversion */
  while(GODONE){  /* Wait for conversion end */
  result = ADRESH;
  result <<= 8U;
  result |= ADRESL;
  return result;
/*--- End of Function ---*/
parimi.ravikiran
Pune
Thanks dude ...
small doubt in the main while calling the read_ad(?); the parameters need to give
bcoz
it takes the channel here.. i am not getting this line
btbass
Oberon
The channel is the A/D input you want to read.
So you would define them something like this:
#define SUPPLY_VOLTAGE  0    /* A/D channel AN0 */
#define MOTOR_CURRENT   1    /* A/D channel AN1 */
/* Call A/D routine */
psu_volts = read_ad(SUPPLY_VOLTAGE);  /* Read A/D channel AN0 */
current  = read_ad(MOTOR_CURRENT);    /* Read A/D channel AN1 */
Or you could just use the channel number
result = read_ad(4); /* Read A/D channel AN4 */
The channel number is shifted into the correct position and ored with the register.
The U after the 2 tells the compiler that the 2 is an unsigned variable.
parimi.ravikiran
Pune
Thanks a lot man
i got it ..u r explanation is superb..
got the result
parimi.ravikiran
Pune
Just i want to know,while next time receiving the adc o/p with different voltage input from Variable pot the ARSESH and ADRESL are giving the previous result only why so?
btbass
Oberon
Don't know?
Show us what code you are using.
parimi.ravikiran
Pune
i am using miKroC compiler pic16f882.
simulation in Proteus is showing some o/p but its not correct
Hard ware shows nothing o/p
my code::
unsigned int result1;
unsigned int read_ad(char);
void main()
OSCCON=0X71; // INTERNAL CLOCK FREQ 8MHZ,SCS Internal oscillator is used for system clock
TRISB=0; //ADC O/P PORTB FOR LOWER BITS (0-7) USING RIGHT JUSTIFIED
TRISC=0; // ADC O/P HIGHER BITS (8-9)
ANSEL=0x10; //ANS4 Analog i/p
portb|=2; //my optional
delay_ms(1000); //my optional
out=read_ad(4);
// send the 0-7 bits of adc result to the portb ( LSB 1st) *
PORTB=out; // portb will contain the result of adc (1-8)lsb 1st
//portc=out>>8;
// send the 8-9 bits of adc result to the portb (MSB END)
/* calling function*/
while(acquisition_time--) /* Sample channel */
//GO=0x01; or GO=1; /* Start conversion */ It is not working for me miKroC
//GO=1;
ADCON0|=2; //go=1
portb=0x00; //optional
portc|=2; //my optional
//while((ADIF&0x01)&(GO&0x00))
//while(ADIF==1&GO==0x00)
//while(ADIF&0x01)/* Wait for conversion end */
while(GO&0x00) // while(GO) is not working here
portc=0x00; //my optional
PORTC=ADRESH; //msb bit (10, 9 ) send to portc
result1 = ADRESH;
result1 <<= 8U;
result1 |= ADRESL;
//portb=ADRESL; //bit (8, 1 ) send to portb
return result1;
dayanpad
Colombo
read This example code reads analog value from channel 2 and displays it on PORTB and PORTC. this is work perfectly then try to understand your code that it is included necessary codes
unsigned int temp_res;
void main() {
ANSEL = 0x04; // Configure AN2 pin as analog
ANSELH = 0; // Configure other AN pins as digital I/O
C1ON_bit = 0; // Disable comparators
C2ON_bit = 0;
TRISA = 0xFF; // PORTA is input
TRISC = 0; // PORTC is output
TRISB = 0; // PORTB is output
do {
temp_res = ADC_Read(2); // Get 10-bit results of AD conversion
PORTB = temp_res; // Send lower 8 bits to PORTB
PORTC = temp_res >> 8; // Send 2 most significant bits to RC1, RC0
} while(1);
parimi.ravikiran
Pune
Thanks both of u , finally it is working ..
here is my code any fineness is required just tell me
All i have observed the o/p on led
now i have 2 work on taking this data to the LCD
CODE::pIC16F882 INTERNAL ADC USING MIKROC
unsigned int result1,temp_result;
void main()
OSCCON=0X61; // INTERNAL CLOCK FREQ 4MHZ,SCS Internal oscillator is used for system clock
TRISA=0XFF; // ADC INPUT PORTA
ANSELH=0; //Configure other AN pins as digital I/O
C1ON_BIT=0; // disable comparator
C2ON_BIT=0;
do
temp_result=read_ad(4); //Read the adc function
PORTB=temp_result; // portb will contain the result of adc (1-8)lsb 1st
PORTC=temp_result>>8; // send the 8-9 bits of adc result to the portc(RC0,RC1) (MSB END)
}while(1);
GO_DONE_BIT = 1U;
//while((ADIF&0x01)&(GO_DONE_BIT&0x00))
while(GO_DONE_BIT) // use this for mikroC
result1 = ADRESH;
result1 <<= 8U;
result1 |= ADRESL;
return result1;
