Can Allegro import a bitmap such as logo in?
john5888
Junior Member level 3
Is there any method the Allegro can import a bitmap?
You can change the bitmap to the dxf,then allegro can import the dxf file!
Does it need to some setting for importing DXF,
I tried it before, from DXF to Allegro, but the can not see
anything in Allegro, all black.....
If you want to import the DXF file into the Allegro, you need to have the crv file which is coversion file.
