bobsun
Full Member level 2
Can a stepper motor be driven by batteries?
Parameter:
Nominal voltage: 5V
Current: 700mA
For standard AAA batteries, the voltage is 1.5 each, so putting three or four in series would provide enough current. However, I wonder if AAA battery could deliver 700mA of current? 700mA is close to 1A, and is in fact quite large from many perspectives. Is there any example that stepper motors of this class is driven by consumer batteries?
I had some difficulties in getting the maximum rating of current for batteries. For example, many batteries are marked with only the capacity like 700mAh for an AAA battery. The nominal voltage of AAA battery is 1.5V, but how could I know this 700mAh rating is for either
https://en.wikipedia.org/wiki/Battery_(electricity)#Battery_capacity_and_discharging seems to suggest that the convention is actually a 20× multiplication:
So does it mean a 700mAh battery could only supply a constant current of 35mA? It seems pretty frustrating since if this is true then there is no way such a battery can drive the stepper motor above.
Hope someone could help.
Bob
Parameter:
Nominal voltage: 5V
Current: 700mA
- 700mA over 1 hour
- 70mA over 10 hour
The battery capacity that battery manufacturers print on a battery is usually the product of 20 hours multiplied by the maximum constant current that a new battery can supply for 20 hours at 68 F° (20 C°), down to a predetermined terminal voltage per cell. A battery rated at 100 A·h will deliver 5 A over a 20 hour period at room temperature. However, if it is instead discharged at 50 A, it will have a lower apparent capacity.[45]
Bob
