Can a C function return 2 values?
Re: c function ?
No. The work around is you can update any number of values in an array or structure which is declared globally and then use the updated values in the global variable.
c function ?
You could put the two values into a struct, and then return the struct.
Re: c function ?
Just a hint...
In my experience, the function should return an error code, usually.
And te real "returned" values(computed in the function body) should be returned via function parameters.
c function ?
That's probably not the best approach if, for example, the function returns the product of two complex numbers.
