Calibre PEX error, especially Compilation Error
heein
Newbie level 3
울산, South Korea
Hello guys.
I entered a problem during PEX in calibre.
As you can see in the picture, compilation is failed.
I don't know how to solve this problem.
Is there anyone who knows the solution?
Please help me.
regards,
Fatal compilation PEX error in calibre
Hello guys
After finishing layout, DRC, and LVS, I proceed PEX.
However, I met PEX error!!!
As I uploaded the error window, compilation is failed.
If you know the solution, please help me
Thanks,
Regards,
A fetal error during PEX in calibre, especially compilation error
Hello guys
Especially, compilation is failed.
( Error while compiling rules file
SVRF syntax error on encrypted line xxx of rules.
NOTE: this is not a decryption error.)
Thanks,
Regards,
Because the rules are encrypted, there is nothing you can do to fix it. (Because the DRC and LVS rules work okay, I am assuming you have the right libraries, supported OS, hardware, etc, and the problem really is in the encrypted file.) Best bet is to contact the group who provided the encrypted PEX rules.
Reactions: heein
    heein
Hi heein
Are you sure you are loading the PEX ruledeck and not che technology description file (occasionally called rules)? Very often the pex rule deck is the same as the LVS rules with an additional internal variable set to -among other things- include the stack description file (usually only this file is encrypted)
Posted via Topify using iPhone/iPad
Reactions: heein
    heein
Hi slizak
Thanks for your opinion.
Finally the problem is related with the version of the calibre.
After I update my calibre version from 2010 to 2012, it is working.
Thanks,
Regards,
