lvs different numbers of ports
1# invert.lvs.report:
Error: Different numbers of ports.
Error: Power or ground net missing.
Layout Source Component Type
Ports: 0 4 *
Nets: 6 4 *
Instances: 1 0 * MN (4 pins)
1 0 * MP (4 pins)
0 1 * INV (2 pins)
2#chrt018.laymap.cal
LAYER MAP 30 TEXTTYPE 10 1030 // Poly2 Labels
LAYER POLY2TXT 1030
LAYER MAP 34 TEXTTYPE 10 1034 // Metal1 Labels
LAYER M1TXT 1034
ATTACH POLY2TXT gply
ATTACH M1TXT M1_nodev
ATTACH M2TXT M2_nodev
3#techfile1.tf
( ("Metal1" "label") 34 10 t )
( ("Metal1" "Blockage") 34 5 t )
from 1, we can know ports are missing, from 2 and 3, we should use ( "Metal1" "label" ). Following these, i still failed. why? elp!!
Added after 5 hours 42 minutes:
It has been solved. we should use ( "Metal1" "label" ).
