[SOLVED] Calibre DRC error exporting layout
The_Dutchman
Member level 1
Member level 1
Hello all,
I have a strange problem running DRC check using calibre. When I start Virtuoso, license "111" is succesfully checked out and everything works fine (Schematic, Layout, MMSIM).
I implemented the Calibre skill interface in the .cdsinit and the drop down menu in layout editor appears. When I start calibre from within the layout editor drop down, the calibre gui pops up and the calibre-interactive license is succesfully checked out.
However when I then try to run the Calibre DRC somehow it tries to check the Virtuoso "111" license and fails prompting the error message below (things go bad during export I think):
//  Calibre layout-server initialized successfully at socket 9199, host Somehost.localdomain.
//  Calibre Interactive - DRC  v2014.1_17.12    Thu Feb 27 15:53:54 PST 2014
//        Copyright Mentor Graphics Corporation 1996-2014
//                       All Rights Reserved.
//   THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
//      WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
//        OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
//  Mentor Graphics software executing under x86-64 Linux
//  Running on Linux Somehost.localdomain 3.10.0-123.9.3.el7.x86_64 #1 SMP Thu Nov 6 15:06:03 UTC 2014 x86_64
//  64 bit virtual addressing enabled
//  Starting time: Fri Dec 19 09:07:20 2014
//  mgc_s license acquired (calinteractive requested).
//  Calibre Interactive authorized.
*** Calibre Interactive: Exporting layout for library "xv", cell "DRCtest", view "layout" ***
WARNING: HOST <Somehost.localdomain> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
*Error* License "111" could not be checked out.
ERROR (XSTRM-209): Virtuoso Framework License (111) could not be found. Either the license server is down or the license is not available. Ensure that the valid license is available.
INFO (XSTRM-273): Translation failed. '1' error(s) and '0' warning(s) found.
I am sure that license 111 is available because else Virtuoso would not run. The warnings can be neglected (everything runs fine, I think it is missing the /etc/redhat-release to be a known supported configuration).
Status of the license servers is given below, the servers are up and if I check the log files all feautures are found and the deamons are running:
./lmstat -A
lmstat - Copyright (c) 1989-2011 Flexera Software, Inc. All Rights Reserved.
Flexible License Manager status on Fri 12/19/2014 09:32
License server status: 18000@Somehost.localdomain
    License file(s) on Somehost.localdomain: /home/#####/flexlm/cadence.dat:
Somehost.localdomain: license server UP (MASTER) v10.8
Vendor daemon status (on Somehost.localdomain):
    cdslmd: UP v10.8
Feature usage info:
License server status: 18001@Somehost.localdomain
    License file(s) on Somehost.localdomain: /home/#####/Calibre2014.1.17.12/ixl_cal_2014.1_17.12/shared/license/license.dat:
Somehost.localdomain: license server UP (MASTER) v11.10
     mgcld: UP v11.10
Feature usage info:
Any ideas of what I can try or check?
Thanks
EDIT: The error is not Calibre related. I tried to do a DRC check with a exported layout stream.
I get the exact same error when I try to export the stream using Virtuoso -> export -> stream.
EDIT: All was solved relatively quickly by patching the long signatures in the license files.
