elec-eng
Full Member level 5
calibre license
Hi all
I recently instaleed Calibre 2006 on CentOS 4.6 on virtual machine "VmWare"
I aimed to use it at the server "i.e no client"
I added the following lines to the license file
also I added the following lines to my .bashrc file
I started the server by typing
the log file is OK
but calibre cannot acquire the license
for example, when I run "./calibredrv" , the following appears
Also when starting the gui "by typing Calibre -gui", the follwing message comes
also the following WARNING appears
so how to overcome the licensing error
and which Linux distribution is recommended for calibre
Hi all
SERVER localhost 000c29152587 1717
DAEMON mgcld /usr/calibre2006/pkgs/mgls/lib/mgcld
export LM_LICENSE_FILE=/usr/calibre2006/license.txt
export MGC_HOME=/usr/calibre2006
/usr/calibre2006/pkgs/mgls/bin/lmgrd -c /usr/calibre2006/license.txt -l /usr/calibre2006/log.log
the log file is OK
1:11:56 (lmgrd) lmgrd running as root:
1:11:56 (lmgrd) This is a potential security problem
1:11:56 (lmgrd) And is not recommended
1:11:56 (lmgrd) FLEXlm (v9.50) started on localhost (linux) (2/9/2009)
1:11:56 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All rights reserved.
1:11:56 (lmgrd) US Patents 5,390,297 and 5,671,412.
1:11:56 (lmgrd) World Wide Web: [I]**broken link removed**[/I]
1:11:56 (lmgrd) License file(s): /usr/calibre2006/license.txt
1:11:56 (lmgrd) lmgrd tcp-port 1717
1:11:56 (lmgrd) Starting vendor daemons ...
1:11:56 (mgcld) FLEXlm version 9.50
1:11:56 (lmgrd) Started mgcld (internet tcp_port 32801 pid 9177)
1:11:56 (mgcld) Server started on localhost for: mgc_s
1:11:56 (mgcld) mentorall_s admsfspif alteramtivlog
1:11:56 (mgcld) alteramtivsim ams2000_s analoglib_c
1:11:56 (mgcld) asap_c asapperf autocells_s
1:11:56 (mgcld) board500_s bsdall_c caintergratwire
// Encountered Licensing problem:
// A FATAL CS ERROR for mgc_s feature detected
// Encountered Licensing problem during checkout:
// License request for caldesignrev feature failed
No 'caldesignrev' license found.
Searching for 'calmdpview' license.
WARNING: Red Hat Linux Release CentOS is not qualified for use with Calibre products.
