Register Log in
Calibre 2006 Licensing error
elec-eng
Full Member level 5
calibre license
Hi all
I recently instaleed Calibre 2006 on CentOS 4.6 on virtual machine "VmWare"
I aimed to use it at the server "i.e no client"
I added the following lines to the license file
SERVER localhost 000c29152587 1717
DAEMON mgcld /usr/calibre2006/pkgs/mgls/lib/mgcld
also I added the following lines to my .bashrc file
export LM_LICENSE_FILE=/usr/calibre2006/license.txt
export MGC_HOME=/usr/calibre2006
I started the server by typing
/usr/calibre2006/pkgs/mgls/bin/lmgrd -c /usr/calibre2006/license.txt -l /usr/calibre2006/log.log
the log file is OK
1:11:56 (lmgrd) lmgrd running as root:
 1:11:56 (lmgrd) 	This is a potential security problem
 1:11:56 (lmgrd) 	And is not recommended
 1:11:56 (lmgrd) FLEXlm (v9.50) started on localhost (linux) (2/9/2009)
 1:11:56 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All rights reserved.
 1:11:56 (lmgrd) US Patents 5,390,297 and 5,671,412.
 1:11:56 (lmgrd) World Wide Web:  [url]http://www.macrovision.com[/url]
 1:11:56 (lmgrd) License file(s): /usr/calibre2006/license.txt
 1:11:56 (lmgrd) lmgrd tcp-port 1717
 1:11:56 (lmgrd) Starting vendor daemons ...
 1:11:56 (mgcld) FLEXlm version 9.50
 1:11:56 (lmgrd) Started mgcld (internet tcp_port 32801 pid 9177)
 1:11:56 (mgcld) Server started on localhost for:	mgc_s
 1:11:56 (mgcld) mentorall_s	admsfspif	alteramtivlog
 1:11:56 (mgcld) alteramtivsim	ams2000_s	analoglib_c
 1:11:56 (mgcld) asap_c		asapperf	autocells_s
 1:11:56 (mgcld) board500_s	bsdall_c	caintergratwire
but calibre cannot acquire the license
for example, when I run "./calibredrv" , the following appears
// Encountered Licensing problem:
//  A FATAL CS ERROR for mgc_s feature detected
// Encountered Licensing problem during checkout:
//  License request for caldesignrev feature failed
No 'caldesignrev' license found.
Searching for 'calmdpview' license.
Also when starting the gui "by typing Calibre -gui", the follwing message comes
also the following WARNING appears
WARNING: Red Hat Linux Release CentOS is not qualified for use with Calibre products.
so how to overcome the licensing error
and which Linux distribution is recommended for calibre
tsinghua
Full Member level 4
calibre 2006 license
RHEL AS4 works fine with Calibre.
You can set the environment variable LM_LICENSE_FILE to 1717@localhost.
Then you can check the log file to see what is wrong with the license server.
armixic
Member level 1
U.S.A
calibre license error
you can solve this license problem by upgrade your VMware from 5.5 to 6.0.
mustangyhz
Member level 5
calibre license file
license:
SERVER 000c299a08c8
TCP:1717
DAEMON mgcld /home/ysj/calibre/ixl_cal_2005.3_6.10/lib/mgcldEDA
INCREMENT accompactor mgcld 2039.060 13-jun-2039 0 6D9A8A6DDC8679D29A08 \
VENDOR_STRING=23D394BF HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=99 SN=21818
INCREMENT acconnect mgcld 2039.060 13-jun-2039 0 ED9A2ABD2863B2F4B4C3 \
VENDOR_STRING=129874E3 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=42 SN=21818
INCREMENT acctree mgcld 2039.060 13-jun-2039 0 FD4A3A2DCA55E063754F \
VENDOR_STRING=6F6129E9 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=85 SN=21818
INCREMENT accuparts mgcld 2039.060 13-jun-2039 0 5D6ABA1D75081669D431 \
VENDOR_STRING=0637CF0A HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=17 SN=21818
INCREMENT accuparts_s mgcld 2039.060 13-jun-2039 0 1D0AEAED29BF036AB73E \
VENDOR_STRING=50DFE2D6 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=120 SN=21818
INCREMENT accupartsnt mgcld 2039.060 13-jun-2039 0 0D6A3A2DE10F220FB6BF \
VENDOR_STRING=72E18DED HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=57 SN=21818
INCREMENT accupartsnt_s mgcld 2039.060 13-jun-2039 0 9D4A2ADD3E535D6997D7 \
VENDOR_STRING=ECD50D01 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=83 SN=21818
INCREMENT accusim mgcld 2039.060 13-jun-2039 0 4DCA3A1DE7880D3F153D \
VENDOR_STRING=A8ADA974 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=64 SN=21818
INCREMENT accusim2_s mgcld 2039.060 13-jun-2039 0 DD2ACA3DA06AA8D5BE26 \
VENDOR_STRING=0DC3CD65 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=187 SN=21818
INCREMENT accusim2ic_c mgcld 2039.060 13-jun-2039 0 FD6A2A4D191AC0ECCE1B \
VENDOR_STRING=EED43EA9 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
INCREMENT accusim2int mgcld 2039.060 13-jun-2039 0 6DDAAA5D723D682F7464 \
VENDOR_STRING=0F224DE0 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=95 SN=21818
INCREMENT accusim2kerned mgcld 2039.060 13-jun-2039 0 BD7A4A7D5472335BCE08 \
VENDOR_STRING=3AEC943A HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=90 SN=21818
INCREMENT accusim2kernel mgcld 2039.060 13-jun-2039 0 CDBABA6D9B2DD5340119 \
VENDOR_STRING=3307EC65 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=102 SN=21818
INCREMENT accusim2kernent mgcld 2039.060 13-jun-2039 0 0DFABA5D4CB90564D309 \
VENDOR_STRING=02077450 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=106 SN=21818
INCREMENT accusim2kernhs mgcld 2039.060 13-jun-2039 0 5DAA7A7D78F361520F0C \
VENDOR_STRING=EE34308F HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=68 SN=21818
INCREMENT accusim2kernicx mgcld 2039.060 13-jun-2039 0 4DCAFA6D829D699FC748 \
VENDOR_STRING=13CF96D4 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=67 SN=21818
INCREMENT accusim2kernpr mgcld 2039.060 13-jun-2039 0 9D5A9A1DE60E808E05FD \
VENDOR_STRING=052DAAC9 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=72 SN=21818
INCREMENT accusim2time mgcld 2039.060 13-jun-2039 0 5D6A0A3D0CD99A7A6416 \
VENDOR_STRING=336E9657 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=73 SN=21818
INCREMENT accusim2xl mgcld 2039.060 13-jun-2039 0 8DCAEA5D37528831F50A \
VENDOR_STRING=CA76073E HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=48 SN=21818
INCREMENT accusim2xlic_c mgcld 2039.060 13-jun-2039 0 3D8A3A6DC9288D60F10F \
VENDOR_STRING=2E879920 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=47 SN=21818
INCREMENT accusimhdla_s mgcld 2039.060 13-jun-2039 0 AD2A3ADDC59FCCF84FC0 \
VENDOR_STRING=27797421 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=180 SN=21818
INCREMENT accusimnt mgcld 2039.060 13-jun-2039 0 2D7ACA1D8E5D934BB988 \
VENDOR_STRING=5CAFAD94 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=109 SN=21818
INCREMENT actelmsimvhdl mgcld 2039.060 13-jun-2039 0 0DFACA6D18459347F876 \
VENDOR_STRING=A5032263 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
INCREMENT actelmsimvlog mgcld 2039.060 13-jun-2039 0 3D0A2A9D7C85CA01113C \
VENDOR_STRING=9F78E10F HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=28 SN=21818
INCREMENT adms2langrf_s mgcld 2039.060 13-jun-2039 0 3D4A6ACD53C204A73FB5 \
VENDOR_STRING=CD6A6D69 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
INCREMENT admsduallang_s mgcld 2039.060 13-jun-2039 0 ED6A2AFDD9B95AEE38A5 \
VENDOR_STRING=FAC03AC3 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=135 SN=21818
INCREMENT admsfspif mgcld 2039.060 13-jun-2039 0 8D1AEA7DC2510F3C060C \
VENDOR_STRING=1A5F9F67 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=58 SN=21818
INCREMENT admsrfic mgcld 2039.060 13-jun-2039 0 9D7ADAED0872331DFE79 \
VENDOR_STRING=D5E4E85B HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=129 SN=21818
INCREMENT aik mgcld 2039.060 13-jun-2039 0 1D2AFA8D9C63CFB7D332 \
VENDOR_STRING=D9E4D55B HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=117 SN=21818
INCREMENT alcatelback_s mgcld 2039.060 13-jun-2039 0 ED5AEADD28F48C3B2D50 \
VENDOR_STRING=D8D78D4A HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=174 SN=21818
INCREMENT alcatelbacknt_s mgcld 2039.060 13-jun-2039 0 9D9ACA1D87B3C1BFC531 \
VENDOR_STRING=F2D2E42F HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=104 SN=21818
INCREMENT alcatelfront_s mgcld 2039.060 13-jun-2039 0 5D8A9A3D12ADBF6EE12E \
VENDOR_STRING=E63F6BAC HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
INCREMENT alcatelfrontnt_s mgcld 2039.060 13-jun-2039 0 5D5A5ABDAC8B184F298F \
VENDOR_STRING=2045DAAD HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
INCREMENT alfpgavhdl_c mgcld 2039.060 13-jun-2039 0 ED7A9A8D0D89B43A709B \
VENDOR_STRING=A208283D HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=86 SN=21818
INCREMENT alfpgavlog_c mgcld 2039.060 13-jun-2039 0 9DDADAED2F37D8590FB7 \
VENDOR_STRING=A6AA89D4 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=163 SN=21818
INCREMENT alhdl mgcld 2039.060 13-jun-2039 0 DD3ABA8D7D713775BD06 \
VENDOR_STRING=31BDB0F1 HOSTID=000c299a08c8 SUPERSEDE ISSUER=EFA_2009 \
NOTICE="Licensed to dc @ qoo" ck=134 SN=21818
INCREMENT alhdlverilog mgcld 2039.060 13-jun-2039 0 0D3A0A5D926EE565FDB3 \
install:
1. PC解壓縮E028_Calibre.rar
2. 將ixl_cal_2004.4_8.14.exe copy至linux
3. Linux中執行 chmod 755 ixl_cal_2004.4_8.14.exe
4. Linux中執行 ./ixl_cal_2004.4_8.14.exe
5. 將lic_cal.dat copy至linux裡, /home/ysj/calibre/ixl_cal_2005.3_6.10/
修改.bashrc。
export MGC_HOME=/home/eda/calibre
export MGLS_******_FILE=/home/eda/calibre/******.dat
export PATH=$MGC_HOME/bin:$PATH
注意:MGLS_******_FILE行的/home/eda/calibre好像不能用$MGC_HOME替换,会出现找不到******情况(不确定中)
3.修改.cdsinit文件。为了能使Calibre集成到Virtuoso环境中,在.cdsinit文件中加入如下内容:
if( getShellEnvVar("MGC_HOME") then
loadi( strcat( getShellEnvVar("MGC_HOME") "/shared/pkgs/icv/tools/queryskl/calibre.skl"))
result:
open terminal:
not a calid identifier*_FILE=/home/ysj/calibre2006/L2006.1_25/LIC_CALIBRE.dat
calibre -gui
failed to acquire calibre interactive license.
why?help me!!!
elec-eng
Full Member level 5
a fatal cs error for mgc_s feature detected
simply because it is not a calibre license
a calibre license should be like that:
INCREMENT calibredrc mgcld xxxxxxxxxxxxxxxx
INCREMENT calibrelvs mgcld xxxxxxxxxxxxxxxx
INCREMENT calinteractive mgcld xxxxxxxxxxxxxx
notice the feature "calibre interactive" that is necessary to run the gui
ghayas1981
Member level 1
calibre 2006
1st of all u have acquire a license file with calibre license included (as elec-eng mentioned) then follow the instructions of tsinghua. upgrading vm ware wont solv the problem at all
