Calculation of Transmitted power at a distance from transmitter
Lathas
Full Member level 1
The oscillator output is about 3dBm, which is directly fed to an antenna with a gain of 3dBi, is there any way to estimate how far the signal would be transmitted in free space?
Borber
Advanced Member level 5
on third flor
It will be transmitted to infinity. Your receiver sensitivity and it's antenna then determines max usable distance transmitter can reach.
Reactions: Lathas
    Lathas
jiripolivka
Santa Barbara
If your system operates in a free space, the above holds. If there is ground, then depending on frequency the propagation may be affected by it, by the ionosphere, by antenna radiation pattern, and more.
Electro nS
Full Member level 6
Full Member level 6
use FRIIS EQUATION to determine at a distance the amplitude of the signal , then depending on the receiver sensitivity , the maximum transmission distance is determined
